Connecting S7-300 and BC3150/BK3150 (Beckhoff) via PROFIBUS
Mr.Taho
Hi everybody,
I'm a new member.
Everyone who can help me to connect S7-300 (master) to BC3150 *slave* (Beckhoff) via PROFIBUS, pleased. I've configured for BC3150 with 1 BYTE BX OUT/MASTER IN, and the same with S7-300. But when I download the configuration to S7-300 via PC Adapter, PLCs not run and all of LED was flashing.
I don't know why? Could you pleased help me!
Thank you very much!
I suggest going online with the S7 and look at the diagnostics. If the S7 is actually communicating with the BK, then the BK may also have extended diagnostics.
I have a stripped down test bench example of an S7-300 communicating with a BK3150 if you would like it.
My skype is "mr.taho91” could you pleased contact me and show me how to do it?
If possible Can you show me step by step that how to config S7 300? because when i download GSD file of BK3150 it don't have any module what i have in my project (for example: KL1002,KL2004,...)
I'm almost ashamed to say it, but my attempts to configure this from scratch using just the manuals I was able to download failed miserably. I ended up using an existing, working project as a starting point.
^^ but when i try to config file BK3150 GSD, i can't find some module of Beckhoff such as KL1002, KL1004, KL2004 what i'm using for my system :(
