R
I'm working to integrate a SMAR HI302-I and a DC302 to a FFB network, and the SMAR Device Description files don't work. I've contacted SMAR multiple times, spoken to several different people, and have received their good wishes, but no solution. Our team is deeply experienced with FFB, we are the systems integrator arm of a controls OEM.
Has anyone here used the SMAR HI302-I and DC302 in a FFB network? Do you get good technical help when you contact SMAR? This is the first time we've run into a Fieldbus device that didn't communicate, and a technical service team that couldn't fix the problem.
