N
Hi!
I want to understand how IGV settings for 9FA Gas Turbine are decided:
a. What is the designed value for Open IGV position (maximum angle up to which IGV can open) i.e. CSKGVMAX for 9 FA GT. In several posts it is mentioned as 84 degree. Control setting in GE's manual mentions it as 84 degree however now contractor want to change it before Contract Performance Guarantee Test?
b. What will be impact of increasing maximum IGV opening beyond 84 degree? Will it affect life of the gas turbine? Is it advisable to allow setting it beyond 84 degree for contract performance guarantee test?
c. GEK 110899 say that correction curves are dependent on IGV angle. Will increase in maximum IGV open angle result in increase in GT output and increased exhaust mass flow? If yes, will it lead to change in correction curve?
d. For Contract Performance Guarantee Test, should CSKGVMAX be kept at 84 degree as correction curves for PG Test had been submitted at the time of award or should GE be allowed to submit revised correction curve based on change in maximum open IGV angle?
Since, this is my first post in the forum, kindly excuse me if I have posted my query in wrong forum.
In case additional information is required, please let me know.
