I would like to ask you about a problem we had recament at a GE MS5002C turbine, and I hope you can give me an answer.
the problem is summarized as follows:
When starting the hydraulic pump 88HQ was high alarmed DP hydraulic oil filters 63HF and high vibration at the auxiliary compartment. we changed the cartridges without result. the cartridge was downright extracted and let the empty filter again the same thing. we installed new manometers upstream and downstream of the filters without result. the pressure upstream and downstream 90 bar to 80 bar was dismantled. the three-way valve was found no plugging.
is new oil.
temperature 42 ° C
<b>Moderator's Note:</b> I fixed some spelling and punctuation. Couldn't figure out what "recament" was.
is new oil.
temperature 42 ° C
