Hi everyone,
I am just having a little bit of trouble with the below calculation and was hoping that someone could help.
I can get an answer but not one of the ones below?
Two cylinders with pistons A & B are connected by a pipe containing water. The diameter of A is 125mm and B is 500mm and the face of the smaller piston is 6.0m above the larger. This is the DWT (Deadweight Tester) principle.
What force needs to be applied to the piston of cylinder A to maintain the load of 2,500Kg on the piston of cylinder B?
Tick ONE box:
a. 764 N
b. 764 Pa
c. 64 KN
d. 1528 N
Tick ONE box:
a. 764 N
b. 764 Pa
c. 64 KN
d. 1528 N
