Hi All,
I am trying to program an S7200 PLC, but have run into many headaches!
While I am very confident in myself with S5 and S7 (300/400), I know that even the simplest code I write for the higher end systems does not work in the S7200, like a "flip flop" or "toggle" for instance and requires a work around.
I am trying to use one push button to control two auto routines based on the status on one flag that is on or off but it fails to work.
I have tried many things that I know will work in the higher end systems but it will not work in S7200. I see in the help manual that the S7200 seems to work with a stack where I have never seen this in all my years of working with the higher end systems.
What is the quickest way to learn the intricacies of this system or some ideas to accomplish what should be relatively simple tasks to solve?
Dan
Dan
