I need to remove a HART signal from a 4-20ma. I will not be using the HART signal, and it interferes with the 4-20ma input signal. Siemens does not offer the device without HART.
I can convert the 4-20ma to 1-5v with a 250 ohm resistor to ground - will this destroy the HART signal? I am concerned with the HART signal affecting the analog input value.
Any help would be appreciated.
