I am running a compressor that requires 3 phase power. The location where the compressor is located has single phase power so I got a convertor to generate 3 phase power. The issue I am having is while my compressor is running, the first 2 legs are pulling 51 amps, and the third leg is pulling 31 amps. The max the compressor can run is 49 amps. How can I bring the Amps down in my first two legs to be closer to my third leg?
