Respected Sir;
Good day. I am working on a gas turbine two shaft Centaur 4502. We measure the temperature at inlet of third stage nozzle with 6 thermocouple identify by T5. The readings of thermocouples are different and from these readings the delta and spread are calculate.
The some turbines measure the EGT and also calculate the temperature delta and spread.
I want to ask what is the difference between delta and spread and what effect of these readings on gas turbine health?
Please help me to clear this point.
Thanking you i will remain
James
James
