I'm using the above coupler between TEC 2000 (MOV) and a Deltav Foundation Fieldbus(FF) card. The current connection (configuration) is not working. I cannot send signal to and from MOV through the coupler. Coupler does not receive signal from the DCS neither does it transmit signal from the MOV to the DCS.
The connect is this:
The FF cable is connected straight to coupler and from the coupler straight to the MOV(Final Field Element) with no terminal in between the coupler and MOV.
Please, kindly advise
1. the best connection I can do to be able to send and receive signal from a remote DCS location using 2:1 procedure.
2. parameter "Actuator Fail Action" to set to be able to receive a field back
3. do I need a Field Terminal Block?
Note: currently, the following error is in the transducer block "Error before start: Valve is not in final position"
Thanks,
Thanks,
