W
Hey guys,
I want to know the reason and solution of the problem that we are facing at our power plant (CCPP) with steam turbine admission control valve. We have installed the new servo valve a month ago. what we are facing is command for valve is increasing/decreasing as per load demand and process control, but the feedback or valve's actual response is changing after 30 sec delay which is not acceptable. We have checked control oil pressure as well and that is normal.
So guys please give me a solution.
