There is a block of software in our system used to calculate the output to a control valve (actually the SRV). Inside the block is a multiplier that is labeled as "scan time". Does anyone know how this scan time is determined?
Also, internal to the block is another calculation that is represented by a square with a "-1" and a "Z" inside the square. I believe this is a shift function from my old MKV knowledge, but I just don't have a clear understanding. If someone can help, I'd appreciate it.
Thanks!
Thanks!
