Hello All,
My query is about analog ampere meters that I recently installed to measure load of induction motors (90KW). When I installed it about 15 meters away the ampere meters showed variations i.e if the load of the motor was 70 Amperes it is showing around 100 A even after calibration it does not work properly. When I installed it on the panel near CT it works properly so I am planning to use a shielded cable for it or can that be a CT (current Transformer) problem which is highly unlikely.
