Can we adjust the flow rate to turbine such that generator can produce any amount of power (0 to its rated value). I read in some books that if the generator is in operation (connected to the grid or any local network), there should be a minimum amount of load on the generator why?
What actually mean by prohibited zone of operation of turbine generator set? Will each T-G set (in general) has the prohibited operating zones or it applicable to certain types of designs?
Whats mean by ramp rates and valve point effect and how they affects the generator real power output?
