K
I am working in combine cycle power plant. We have 260MW four STG available at our plant. We are facing problem in STG condenser level transmitter. we have DP type level transmitter with condensate pot.
In each STG we have three DP transmitter with individual condensate pot available at our plant. it has observed that at normally 15 to 20 we found transmitter reading drifting in one out of three transmitter. during checking found its condensate pot empty.
We checked following things to solve problem
- check transmitter installation found ok
- leakage checked and found no leakage
- check insulation of condensate pot and found normal
One observation is that for all three condensate pot we have common isolation valve. after isolation valve we have individual isolation valve for each condensate pot. Is this one reason for level transmitter reading deviation?
Please advise and suggest what to do.
