recently we overhauled the LP turbine after assembly of turbine the rotor was moved with hand cranking mechanism and was moving effortlessly. after that the turning gear was engaged and and machine was put on turning gear for two hours but during this seal oil system was not started and there was no hydrogen in the generator.
next day when seal oil system was started without hydrogen in the generator the barring gear did not engaged and barring/turning gear motor is tripping again and again on overload.
My question is can we engage the turning gear without starting seal oil pumps as there is no hydrogen in the generator?
Stating oil pump in service
lube oil pressure ok.
