i am working on a plant where we have two ge frame 9e turbines, and we have markvi as control system which runs on windows xp environment. we have two hmi one for each turbine in local control room and one in the central control room for controlling both turbines. currently one hmi in the local control room has crashed, but both turbines are running and are now controlled from central control room and our guarantee period has also expired.
now as a fairly fresh control control engineer, i am not sure how to solve this problem, but i was wondering if we load all the necessary software to a pc in xp environment, will that work? or is there any restriction or modification need to be done.
thank you
thank you
