Q
Level Transmitter of Mobery LT100 displacer type is working OK in workshop but after installation in area showing indication in minus -35% instead 0%. While there is no physical level in compressor knock out drum.
Kindly help me regarding this type of LT problem as indication is going to minus side.
Services: water condensate of knock out drum, Air compressor.
Pressure round 15 Kg/cm2 maximum.
Qamar Ali
Qamar Ali
