F
I have some questions about the general electric MS9001E or Frame 9E
1- What is the function of the 4 oil deflectors mounted on the bearing 2 liner strap?
2- why there are 10 holes on the each side of the bearing 2 liner just below the oil deflectors?
and what is the function of the so called "spray holes" located on the top of the liner strap? "as seen on the maintenance manual"
3- What is the function of the vent holes located in between the forward oil seal and the forward air deflector on bearing 3?
4- Why the load coupling compartment is positively ventilated unlike other compartment?
5- Why we don't have 2nd stage shroud cooling while having third stage shroud is cooled by 5th stage air extraction despite being in lower gas temperatures?
6- Does the 5th stage air extraction used to cool the third stage shroud flows continuously or just static air?
if there is a flow , where does the air exits from the third shroud? "gaps between segments?"
7- what is the function of the holes under the transition piece aft bracket?
8-why specifically with DLN system we have sealing air coming from the 11th stage plus the 5th stage?
on standard we use the 5th stage only ... what changed?
thanks in advance
thanks in advance
