Im using an FMU90 & FDU91 sensor. I have been facing an issue on FDU91 sensor. it is installed in an Elevated potable water tank. This tank has two compartment due to which it has two sensors. This elevated tank is been fed by a booster pump station. The problem which i face sometimes is one of the sensor value is fluctuating from the correct level to higher value and comes back to correct value. This is interrupting my pump operation in auto. The sensor was replaced by another one, but faced the same issue after some trials. The cables were swapped with the other compartment sensor and it works fine with it. Funny part is that the other sensor is working just fine with other cables.
I kindly request somebody share their thoughts to resolve.
Mufeedh
Mufeedh
