T
I have a BAS system that outputs 15vdc @ 20mA that supposed to drive a 2 wire loop powered control valve that has 600 ohms load. The 15vdc is is to low and I want to know is there a way to boost the 15vdc to 24vdc?
R | How To Read an Instrument Loop Diagram | Process Control | 1 | |
W | Instrument Control Loop | Process Control | 3 | |
N | Field Instrument Power Loop Malfunction | Programmable Logic Controller - PLC | 1 | |
C | Non loop power instrument impact to BMS | Process Control | 3 | |
B | Instrument Loop Drawing | Process Control | 5 |
