F
while Gas turbine is running full speed sometimes giving speed deviation N1 and shut down.
I checked speed sensors. The speed sensors contacted Beckoff signal contioner card (KL5151) and inremental card. I checked speed transducer kHz/4-20mA, and analog input card. I didn't solve this problem.
The problem occurs are sometimes nearly 8 hours some times nearly 2- 3 days.
What else should I check?
What could be the problem?
