Z
Currently I'm having a communication issue with an IMT 25 Flow Transmitter. The display on the transmitter reads correctly, the hart 475 reads the transmitter output correctly, and when I input a signal to the terminal block the DCS reads the correct value, yet when I hook up the instrument to the terminal block I am unable to get a reading on the DCS. Just to note, I have also tried reassigning the instrument to different channels on the terminal block and I was still unable to read any values on the DCS.
