N
I'm trying to connect multiple KUKA robots to a SCADA running on a PC over EtherNet/IP. KUKA robots support the EtherNet/IP protocol, but what SCADA and hardware must i use on the PC?
Are there EtherNet/IP drivers for standard Ethernet adapters or do i need separate hardware?
Is there a low-cost SCADA which supports EtherNet/IP that i can use to communicate with the KUKA robots?
