Hello Sir,
pls can u explain to me the effect of a negative (-ve) Megawatt-volt-ampere-reactive (MVAR) means in a frame 9E gas turbine during generation? eg we are generating and is showing Gen.50/-0.7 (active-reactive).
I have seen different reading showing the active and reactive MW/MVAR at negate and positive. pls explain sir, when it is positive and negative, its implications and meanings as it relates to generation.
2. When the frequency during generation fluctuating BTW 48.5, 49.0, 50, 51hz could mean?
