K
hi friends
I am working in Ge turbine frame 5 mark 6 25 MW open cycle (10 combustion chambers, spark plug in 1st and 10th chamber, four flame scanners -2, 3, 7, 8). Last 20 days we are struggling to start GT.
On 20/3/2015 plant was blackout. After power resumed from grid we start our plant at normal procedure. But ignition failure happened more than 2 startup. We are using liquid fuel as our fuel. We people did following maintenance. we found the fuel pump damaged from inside and we install new fuel pump. then we started it 2 times, and it gave us 4 bar on compition, but with our start and it gave us fail to ignite.
friends what can i do for this problem
[email protected]
[email protected]
