N
It is GE 9E DLN1.0 gas turbine. I am a question when i am reading the CSP. I hope someone could help me.
I find FSRP is not directly assigned to as fsrout. Instead of that, there are several steps of modification before it is output to Servo Card.
Following is the main line:
FSRP==FFRG1X==FFRG1
FSRP: FUEL STROKE REFERENCE PRIMARY
FFRG1X: FGCV #1 Heat Rate Flow Reference
FFRG1: FGCV #1 Heat Rate Flow Reference
FSRP equals FFRG1X and FFPG1,but the signal name changed from stroke reference to Heat Rate Flow Reference. That is wired.
FQRG1_V1= FQRG1/ FQKCNST1/ FSRG1FP/ FPG2AF
FQRG1: FGCV #1 Flow Reference (#/sec) + Prefill;
FSRG1FP: Fuel Gas Valve G1 Piping geometry factor;
FQKCNST1: FLOW CONTROL EQUATION CONSTANT #1;
FPG2AF :FUEL GAS INTERVALVE PRESSURE FILTERED
To be continued (if is asked, I am willing to finish this)
So these is some modification? and it is very complicated?
My question is why these modifications is considered, as traditional combustor doesn't?
Why so much change?
Best regards!
Neo [email protected]
FSRP==FFRG1X==FFRG1
Why so much change?
Best regards!
