Following is the specification of our diesel engine. Can anyone please give me calculation for fuel consumption in Ltr/hr.
Thanks.
Manufacturer : Caterpillar
2) Model : 3616 DITA
3) Type : Direct fuel injection
Turbocharged, After-cooled
4) Rating : 4.8MW at site Condition – standby
5) Speed : 900 rpm
6) Cycle : 4 cycle
7) No. Of cylinder : 16
8) Arrangement of cylinder : VEE
Cylinder bore : 280.0 mm
11) Piston stroke : 300.0 mm
12) Piston speed : 9 m/sec
13) Idle speed : 350 rpm
14) Cylinder displacement / cyl. : 18.5 liters
15) Compression ratio :Type : HSR7 947-8P
2) Output capacity : 6,875.0 kVA
4) Phase, Wire, Connection : 3Φ,4W,Y(DAMPER WINDING)
5) Voltage : AC 13,800 V
6) Current : 287.6 A
Thanks.
5) Speed : 900 rpm
6) Cycle : 4 cycle
