K
Dear readers,
We have GE 5001 gas turbine that we use for power generation along with 3 other gas turbine operating in droop.
Recently this GT was observed to have oil leakage from its axial air compressor, right where extraction air is taken from its 4th stage for turbine shell cooling.
This leakage was observed after the GT was started after a shut down and the only job performed was chemical cleaning of the compressor.
Our best guess is that this oil is travelling from bearing #1 (thrust and journal assembly) right before the compressor.
Can you please highlight any other possibilities for this oil leakage and what its source might be?
