Q
Dear Sir,
Sir we have issue of lube oil consumption high. please help me!
Our machines GE frame 9E gas turbines lube oil consumption weekly basis more than 300 liters. It looks like a leakage somewhere but I have not been able to trace the place. But the unit indicates that lube oil is reducing. Please kindly assist with your knowledge. We also checked the machine exhaust temperature found normal.
Performed Checks,
1. Check negative pressure in the LO tank it is as per OEM recommendations
2. The centrifugal motor-driven type mist eliminator filter installed. New set SAI Brand
3. The OEM had increased the size of the vent piping from 6 10 Inches
4. There is no and external oil leakage
Qurban
KEPCO KPS
Performed Checks,
Qurban
KEPCO KPS
