Hi guys,
In a project I have several analog and digital Beckhoff I/Os. The problem is after a while my analog output module (KL4408) stop working. All the channel maintained at a constant voltage. After I changed the module with a new one again after 2 days it happened again. The module wired to some actuators with 24 Vac. I doubt on the ac and dc ground which they are separated. Should I connect the grounds to solve the issue?
