G
Another engineer specified an orifice plate to measure natural gas flow. The orifice meter is installed in the process line per the installation detail of a gas measurement with orifice plate.
Process Engineer is stating the meter is measuring natural gas accurately. States its of by factor of 10x. He states the flowing pressure and temperature needs to be measured, or compensated.
How accurate is a orifice meter for natural gas measurements? My reading says between 2-4% of full scale. If that's the case, the current installation should work fine.
How do I prove the meter is measuring within a certain accuracy?
Thank you
Thank you
