I need to connect & operate two MODBUS RTU to a PC via solid pilot cable (fo/cat5). i have also RTU to PC interfacing software but it is not possible to connect two RTUs simultaneously on PC if one is running through PC via USB cable. should i need to change any port configuration? or I need any PLC type MUX for running these two simultaneously via cable?
Kindly guide me in this case.
