I was just wondering how much if any damage to the turbine to run with a bleed air valve that is failed and open? Second stage wheelspace upwards of 1200 deg. Power output obviously on the low side because of it.
J | IBH (inlet bleed heat) has lost its marbles | Power Generation | 6 | |
D | Compressor Bleed Valve fail to close | Power Generation | 11 | |
K | Inlet Bleed Heating in DLN#1 | Power Generation | 13 | |
H | Why using bleed valve's at lower power generation? | Power Generation | 14 | |
A | GE Frame 9E Bleed Off Valves Passing | Power Generation | 8 |
by Munir Ahmad
by Seth Price
