H
Hello there
We have a GE frame 6B gas turbine installed at our plant. just wondering if someone can help to know the maximum temperature/pressure of the following:
Atomizing air into compressor (accessory driven)?
Atomizing air outlet compressor (accessory driven)?
Atomizing air output pressure (after AA compressor)?
Maximum air temp into pre-cooler/heat exchanger?
Maximum air temp outlet pre-cooler/heat exchanger?
Hope to hear from you
