O
We have recently upgraded our contro system from speedtronic Mark-II to Mark-VIe control system. The turbine is Frame-III and LP turbine and HP turbine are not physically linked.
Now we are facing problem that during startup as LP turbine failed to cut-in at max of 50% of NHP. Unit tripped on LP shaft locked trip alarm. This setting can be changed and increased up to 52-54%, but i would like know know the hazards involve and effect on turbine specially HP rotor.
Second i would like to know why LP turbine is unable to cut-in at desired state? For last 1 year for every start-up it rotate under 48% speed of NHP.
