W
I have a client that has a 34.5kV 3-phase drop from the utility and several 575VAC 3-phase (secondary) transformers.
Generally speaking, is the secondary of these transformers normally delta (3-phase/3-wire) or Wye (3-phase/4-Wire)? OR is it site dependent on how they are wired?
I've not worked with 575VAC before and wanted to know if anyone has any guidance on how 575V is normally done.
