i have some information on calibration of SRV, GCV but in different control system other that MK's. i wanna know (in details if possible) how to calibrate IGV in MKVIe and before that to know the meaning and effect of the following terminology:
Null Bias
null current
gain
in GCV we used to install a dial gauge to measure the span of actuator shaft and the movement with each current command. what about IGV? what shall we install to measure the angle? do we have to install a dial gauge in IGV actuator also? what is the actuator span in mm? how could we prevent oscillation, max./min position overshooting, and controlling movement speed?
thanking you in advance as always,
Maythem
Null Bias
null current
gain
Maythem
