Emerson ROClink Integer Scaling Issue
R
riverjig
I have several Rosemount pressure transmitters which are ranged 0-2000 PSIG. I am using a ROC800 as the master and bring them in MODBUS using wireless Freewave radios. When I perform the loop check, my 20mA signal shows 1984 PSIG in ROClink. The float scales are correct. I feel it is being scaled incorrectly. I am not proficient enough with the integer scaling to adjust it. I was hoping someone could help shine some light on what I can do to adjust this integer scale. Im hoping that this is the issue.
I would appreciate any help or advice on this subject. I can provide some screen shots if need be. Thanks!!
