N
could somebody help me with the problem in Citectscada v.7.40?
The username is always set to "system" value in SQL Device. So I can't get this field in MS SQL server 2014 R2 database.
The user logs in as "User1", but when I try to get the value of Username, it is set to "system" not "User1". How could this problem be solved?
Thank you
Thank you
