Friend called me with this issue. He is overseeing testing of a new generator stator that was re-wound by GE, we will call it G2. Installed the stator. G1 and G2 already independently checked with a phase rotation meter, check out good. Turned on G1 and closed the G1 CB, load is a resistive only load bank. Fired up G2. Turned on sync scope of G2. Sync scope is rotating slow in the CCW direction. Attempted to increase speed on G2. Sync scope rotates fast in the CCW direction.
