Usually, most of the IDOS and TCI commands have some limited--and cryptic--help available by using the /? or /help (sometimes it's just help) after the command and then pressing ENTER.
Please write back to let us know what you find (if you find something). If not, I'll try to go back through some old, archived notes.
And, when do you see this command? When the <I> or HMI is booting up?
DDI2IP: <I> to <I+> Dictionary Conversion
....XS has determined that the unit type is Mark V.
...Warning: Multiple longnames defined for point L30PRVF_ALM (Same)
...Warning: Multiple longnames defined for point FSR_CONTROL (Same)
...Warning: Multiple longnames defined for point L3SFDIFF (Different)
...Warning: Multiple longnames defined for point SFL2 (Different)
