V
We have a problem to start a MS5001 unit with a diesel motor and a Mark VI control. The unit starts normally but a approx. 43% of TNH the clutch disengages and the turbine trips. We check the jaw clutch and they seem to be ok. The torque converter pressure is too high (130 psig). There was a 20TU that was eliminated and its place a valve with an orifice plate was installed; this valve was found closed and we think that the pressure must be at approx 40-50 psig. What can be the cause which the clutch disengage so early?
Any comment would be appreciated.
