We have 16 digital inputs (Dry contacts) that we would like to monitor them using an already exist HMI with RSVIEW STUDIO. so we should add a digital input module and connect the module the HMI? would you please suggest a cost effective solution? Which module should we use? Which communication method?
Please note the the distance between the system to be monitored and the HMI is about 250m.
Thank you
Thank you
