H
I facing problem with calibrate range for application closed tank under vacuum.
zero level is 840 mm and span is 2840 mm from transmitter and vacuum not constant from 0 to 277 mbar
what can i do for find correct level? i used E+H level transmitter Cerabar S PMC71
not. this system connected to PLC and i think must be used equation for correct the level value according the pressure
