I'm having a problem with a G.E. Frame 5 not accelerating during start up.
We're reaching 19/20% and firing (on liquid), and it teeters between firing/accelerating and cranking. Only achieving flame on 2 from 4 flame scanners. It slowly climbs to 25%, and no more.
I've checked the torque converter and it's getting quite hot. The manual throttle/choke valve seems not to do anything to the speed, the pressure gauge on the line between the torque converter charge pump is only reading 1 bar, regardless of throttle/choke valve position.
I'm thinking that either the charge pump is at fault, or the torque converter is dumping oil, straight through, with possibly 20TU at fault? Although with me fully closing the manual throttle/choke valve on the drain line from the torque converter, I would have expected to see the machine accelerate?
My back to back tried to adjust the manual throttle/choke valve a few weeks ago to overcome a similar problem, so I'm not quite sure what position the valve was in beforehand, as the locking device was not re-attached.
Any ideas people?
Any ideas people?
