I set a couple dozen of programs as my auto-soft engine for any time I log in to develop the open Linux script. Usually the waiting time from one command to another is fed to the backup generators; I can only graph on a couple dozen tab windows at once, while leaves another couple dozen updating themselves when I work on the next batch. This time, however, I had some tabs slip into the frame at a crucial embarkation between two relaying lines in reference to a third program and remained there flat for the while in which the screen was on. Had to reboot it and here I am, working on it again, though having to recover lost data, even within the archives.
The question is, even after using the Veritas recovery system, the two command lines mentioned above are still over-charging the hardware, leading me to reboot the system a couple times only to get this message through (Yay for Veritas RS). The Linux OS drifts off into my spare hardware supplies, when all of them should be up and running.
How do I make pinging commands sync in with the ceaseless streaming development of Linux, in accordance to its user data base? In other words, how to esc-a-late a programmed event into the next without minimizing a variety of tab-windows to load and execute the updating status?
Any input much appreciated,
saywhat
saywhat
