Hi All,
I need some clarification on signal segregation. I have an electrical actuator which has 3 cable entries. 3 signal types will be coming from the actuator, AI (1PR)/AO (1PR) /DO (3PR) plus power cable (total 4 cables).
So my question is, would it be possible to run the AI & AO signals through a two pair cable to reduce the amount of incoming cables (Power, DO, AO/AI combined = total 3 cables)?
also note there is no specific local standard covering this.
Any advice will be highly appreciated.
Max
Max
