V
1.Why 4-20ma is standard instrumentation measurement , Why not it can be 3-19ma or any other... I know the Live zero concept when the cable is cut you won't b able to get 4ma from field .. so if v use 3-19ma as standard wht's wrong in that?
2. Why 250ohm resistance in parallel is used as standard ...whether to get linearity in voltage output??
Kindly give your valuable suggestions
