I tried to interface HART modem AD5700 with DAC161S997 for getting the HART FSK signal from loop current. By using 250ohm connected series with loop supply will only give voltage drop across resistor for varying loop current. Then how can i measure/differentiate the HART FSK signal from loop current?
